Phantom Vision 2 and no more Live Feed
1697 5 2016-3-28
m.friedl
Flight distance : 3 ft
Austria
Hi Guys,
I own also an older P2 Vision and wanted to give some Exercise to my Doughter in Flights.
Have not used it since last Summer 2015 and charged all Batteries again now.
Nothing has changed, only... there was an Update of the Vision-App and now i have no more Live-Feed
Had saved an older Version of the Visionapp too and installed v1.0.48(1677) with same Result - No more Videofeed
I can change all the Settings without any positive Result to regain the Livefeed, have reinstalled the App on my iPhone, i am able to move the Cam using the App but there is still no more Live Feed.
Any suggestions what i can do to fix this ?
I do not want to send my P2V into DJI because it´s not worth the Money for repair because it´s an old Toy.
Maybe i have to replace the Camera ?
Thank you - Mike
2016-3-28
m.friedl
Austria
Update !
In Livechat i´ve got a Hint to Reset the REX and rebind it.
I did it and got back same Result as before.
So the Question is again - what´s the Reason for Blind Screen at the Live Feed?
really nobody knows ???
2016-3-28
EddieR0691
m.friedl@a1.net Posted at 2016-3-28 20:10
Update !
Most likely it's the wifi module that has gone out.
That is IF all of your cables are correctly connected and there is no other damage.
There are lots of threads about P2V's and no live feed.
2016-4-2
johnwarr
Flight distance : 6467 ft
Hi Mike,
I cant offer any personal advice from experience as I have the V+
But, I would check the white cable to the camera is securely plugged in at both ends.
Then open the Vision App and go to about and check the list of firmware versions for both Phantom and Camera, compare it to the last updates from DJI HERE
Phantom should be 3.14 and the Camera should be 1.1.9
IOS app should be 1.0.54 and Android 1.0.59
A lot of the no live view problems are caused by a mismatch of firmware.
Hope this helps you.
2016-4-2
m.friedl
Austria
johnwarr@live.c Posted at 2016-4-2 17:19
Hi Mike,
But, I would check the w ...
Hi john,
yes i have the vision only not the V+
have not the very latest software on, but it worked last year as i sayed and the only change was the App-update.
I did also a restore of the app to the previous version also but nothing changed.
i did the rebind 3 times and everything works without the live-feed.
if you have advice for my old egg just let me know
Mike
2016-4-3
m.friedl
Austria
EddieR0691 Posted at 2016-4-2 13:47
That is IF all of your cables are correctly  ...
i think you are right and it´s gone.
replacement looks to be too expensive for repair
2016-4-3
