Remote Speed controller
507 1 2016-3-28
rbthecraneguy
I have a question about getting the speed function switch to activate on the controller. When I input speeds on the app under the controller window where the 3 toggle speeds can be set, I can test the speeds in the wizard window and it works under the test speeds. When I use the function toggle and switch speeds it will work in the "test speed". However, when I try to switch the toggle switch and use the joystick, the speeds wont change. They are locked to the speed at which the maximum speed is set on the app for "remote speed." Its all a bit confusing actually. I toggle the "Mode" switch as well but it makes no difference. Any help would be appreciated.
2016-3-28
DJI-Adela
Hello!
May I know what RC and what App you are talking about first?
2016-3-29
