Donnie
Flight distance : 3636782 ft
Vonbaron , just go to the Header of this page where it lists the different DJI models: Phantom - Inspire - Osmo- Service - Here you will also see a" magnifying glass" search tool at the far right . Here you can look up old post's. BUT to condition the batteries simply give them a full charge and then for the first 10 flights dont go "Full Bore " and only take the battery down to 50% level . Keep any eye on the voltage to make sure you have a solid pack . After that I would discharge the battery once every 10 cycles down to less than 5% or the aircraft just shuts off. The way I do this is I just fly like normal but get it down to 20% then I make sure to keep the bird very close by ,Then I keep it close to the RTH site and just hover until the pack has hardly enough power to keep it aloft, then I will just land and without powering off the aircraft , I just let the Battery die . This is usually at about 3-4 %. Now do a full charge and that is it. Easy Peasy Lemon Squeezy !
Cheers- donnie
