Donnie
Flight distance : 3636782 ft
Did you update the Go app as well ? Is everything up to date for that matter ? Check the Cable from device to Transmitter. Make sure you have a good one . Be sure to "Enable hardware Decode" on the Go app as well it will take some of the load off the processor. Also clear the video cache on the Go App as well. Also try to lower the resolution in the camera settings from 4k down to 1080p and see if it helps.
Be sure to calibrate the IMU and camera after an update as well .
If I have you check or change everything we will get there eventually . Sorry, it could be any one of a nubmer of things. Make sure you inspect the camera pins as well make sure none are bent, that is why I recommend not taking off the camera unless you must.
Try these for starters - donnie
Be sure to re boot the I pad as well
Take a screen shot if it continues. Hope the suggestions help , keep me posted by replying to my post
donnie
