Ronin + Embedded Systems
1223 5 2016-3-29
Mary
Brazil
Hello,
I'm planing on buying a Ronin, but I want to control it with an embedded system (e.g.: Raspberry Pi). What would be the recommended form of communication between them?
I was thinking about using DBus, but I would like to read the axes' angles and control the maximum speed. Is it possible?
Any recommendation?
Thank you!
2016-3-29
DJI-Adela
Hello!
The D-BUS port on Ronin support 3rd party transmitters/receivers.
2016-3-29
Mary
Brazil
Can I read axes' angles with DBus?
2016-3-30
Mary
Brazil
Is the Ronin-M compatible with the onboard-SDK ( https://developer.dji.com/onboard-sdk/documentation/OPENProtocol/) ?
2016-3-30
DJI-Adela
Mary Posted at 2016-3-30 19:57
By connecting the Ronin to DJI PC/MAC Assistant software or DJI Ronin Assistant App, you can see the live date of Pan, Tilt and Roll axes.
2016-3-30
DJI-Adela
Mary Posted at 2016-3-30 20:55
Is the Ronin-M compatible with the onboard-SDK ( https://developer.dji.com/onboard-sdk/documentatio ...
Unfortunately, Ronin-M is not compatible with the onboard-SDK at present.
Thanks for your concern!
2016-3-30
