video storage
1388 5 2016-3-30
HyRoProductions
Flight distance : 3251 ft
I captured some 4K video but it show on my Tablet.
Is there a setting that I can set to store on the SD card only? I know my tablet will not have enough disk storage to keep it.
Thanks.
2016-3-30
jrm11
Flight distance : 224577 ft
The video is recorded onto the SD card.  There is a lower-resolution copy (720p, I believe) on your tablet.
You need to copy the 4k files from your SD card to your computer.
2016-3-30
CaptRuss
I believe that, if you go into Go App's Settings / Other / Video Cache, you can slide the "Cache locally when recording" switch to off, and this will disable the saving (caching) of video to your mobile device.  In that event, it will be saved only to the SD card.  Hope this helps-  Russ
2016-3-30
HyRoProductions
jrm11 Posted at 2016-3-30 14:44
The video is recorded onto the SD card.  There is a lower-resolution copy (720p, I believe) on your  ...
Thank you jrm11!
2016-3-30
Geebax
CaptRuss's answer addresses your problem. Even if you do still cache the videos to your device, it will automatically delete the older ones as space is used up.
2016-3-30
DJI-Paladin
Flight distance : 2408 ft
jrm11 Posted at 2016-3-31 05:44
Correct. And you can also disable Video Cache option in order to save the files in the SD card only like what Russ said
2016-3-30
