cornel
Flight distance : 62736 ft
Romania
Hello Donnie,
I see you helped quite a few people with jammed RCs and I hope you'll be able to help me as well.
I think I understand what I have to do from other posts in this thread, but I would like to know for sure I'm doing the right thing before doing something stupid and irreversible.
Here'e the history: I have an Inspire 1 AC with 2 RC (master+slave) used last time around January 2016 (probably firmware 1.3 or 1.4, I'm not sure). Worked fine.
Yesterday I tuned it on as usual, and, of course, it requested firmware update for RC and AC. Did updates on both RCs via the application (I guess v1.6, don't know for sure), everything fine, did update to the AC via SD card also successful (v1.8).
Restarted the whole system, and I got "NO SIGNAL" message on the master RC, altough I had image and I could move the camera using the slave RC sticks and using the master RC gimbal wheel.
The gimbal also moved slightly when I moved the ruder stick right or left, but I just couldn't start the motors.
However, the AC led kept on flashing yellow, which per manual means "NO SIGNAL".
I tried and successfully rebound the RC with the AC, but still "NO SIGNAL" appeared in the status bar of the app, AC led flashing yellor and the motors wouldn't start.
I thought the master RC had something so I tried to turn the slave RC into master RC, so I selected master in the app and shortly after I got notification that a firmware upgrade is available.
A bit strange, but I thought maybe it needs something else to become a master so I tapped "download". Downloaded fine, tapped "install" and failed! Immediately, the RC led tuned light green.
Manual doesn't say anything about a light green led! I also noticed that the RC doesn't make any sound when you press the button and when it starts.
Tapped "retry" and it said disconnected. Since that point, that RC had no image, no connection, no signal, it's completely jammed.
But I had one RC left :-) so I moved to that one and don't know what I did but I got to the same point where it requested firmware upgrade, downloaded the package, tried to install, failed, light green led, and another jammed RC.
So I've got two jammed RCs now, damn it!
Here's a video with how the situation looks right now:
https://www.dropbox.com/s/puc7tx ... 515_102547.mp4?dl=0
Can you tell me what should I try to do now? |
