Forward and downward vision sensor calibration errors
12Next >
53591 73 2016-4-3
jwalker59
Flight distance : 37369 ft
Norway
New problem.  Every time I start the aircraft and remote, I am getting the errors "downward vision sensor calibration error", "forward vision sersor calibration error" and "vision sersor communication error 10c00".  I have, thus far, been able to restart SEVERAL times and it has gone away and all works fine.  HELP
2016-4-3
DJI-Paladin
Flight distance : 2408 ft
Hello, I'd suggest you to install the latest DJI Assistant 2 and calibrate the vision system via this software and PC. It would be better to clean the vision system before calibration:
https://www.djivideos.com/video_ ... d-afa8-3d4082064a81
2016-4-6
adkornelsen
DJI-Paladin Posted at 2016-4-6 03:11
Hello, I'd suggest you to install the latest DJI Assistant 2 and calibrate the vision system via thi ...
I've had the same problems ever since I updated to the latest firmware. i don't know what to do.  I also noticed when I have these problems the firmware version says "unknown" yet when it randomly decides to work it tells me I'm running the current verison.
2016-5-4
DJI-Paladin
China
adkornelsen Posted at 2016-5-5 09:34
I've had the same problems ever since I updated to the latest firmware. i don't know what to do.   ...
It is recommended to re-upgrade the firmware via DJI Assistant 2 again.
2016-5-4
juliovincentyjr
Flight distance : 829908 ft
I had the same problem. After calibrating the vision sensors via the assistant 2 program I haven't experience yet. I'm on my 5th flight after to calibration. So far p good.
2016-5-4
evgenij911
Ukraine
friends, why I do not have to calibrate button ??? how to calibrate for each flight if there is no button?
2016-6-25
r62ewa
Flight distance : 2463996 ft
evgenij911@mail Posted at 2016-6-25 15:54
friends, why I do not have to calibrate button ??? how to calibrate for each flight if there is no  ...
You are just looking at the Status page for the sensors.  In order to calibrate them you have to go into the Settings, IMU calibration is under Sensors.
2016-6-27
GRUMPY69
Flight distance : 13711 ft
cant find the latest DJI Assistant 2 for windows 7,,,,found one but that doesnt have the settings that everyone talks about so must be an older one,please help me
i need to fix my mavic pro
2017-1-8
Aardvark
Flight distance : 384432 ft
GRUMPY69 Posted at 2017-1-8 14:13
Have a look Here. A good page to bookmark as lots of bits to look at.
Video guide :- https://www.djivideos.com/video_ ... d-afa8-3d4082064a81
2017-1-8
fans00bd3594
Flight distance : 83386 ft
Aardvark Posted at 2017-1-8 16:17
Video guide :- https://www.djivideos.com/video_play/57301fc0-978b-4d7d-afa8-3d4082064a81
I have the DJI Go app installed on my iPhone. I just noticed that the DJI Mavic and P4Pro require the DJI GO 4 app. Once I started using the DJI Go 4 application, the error no longer exists. Now, I wonder if the DJI Go 4 app supports my older P3 Advacned...hmmm, that's a whole new question.
2017-2-10
Aardvark
fans00bd3594 Posted at 2017-2-10 08:33
DJI Go 4 does not support the P3 range. It's for P4, P4Pro, Mavic, Inspire2.
2017-2-10
sharath sam
India
im also havn
2017-2-11
sharath sam
India
im also having that same problem.... how to solve this... Forward and downward vision sensor calibration errors
2017-2-11
fansbb9ac8d7
Flight distance : 42680 ft
I'm having this problem too, I'm also still getting a battery error. It keeps telling me to reconnect the battery. Because of the weather I hadn't really flown a lot, I'm just hoping all this would be cleared up before the weather clears up.
2017-2-11
Aardvark
sharath sam Posted at 2017-2-11 02:04
Calibrate the vison sensors using DJI Assistant 2 from Here (a good bookmark, lots of goodies).
This video can be used as a guide, latest Assistant 2 might look slightly different, but principles the same:--
2017-2-11
fansbb9ac8d7
Thanks. I guess I'll have to give it a try. I've never use the Assist app I just like to fly around and take pictures. When I first got it I never had any problems with it. Now every time I go to fly I have to update something.
2017-2-11
sharath sam
India
thank you...
2017-2-11
x1War Monger1x
Flight distance : 1880 ft
DJI-Paladin Posted at 2016-4-6 00:11
i am currently going through the same problem. it is telling me to calibrate the vision sensors. I have tried doing it and it tells me that it has failed and retry every time. I have downloaded the dji assistant 2 and the only thing on it is to update the firmware. there is NO option to calibrate the sensors. how can I fix this.
2017-2-13
Aardvark
x1War Monger1x Posted at 2017-2-13 16:53
It should look something like this, click on the 'calibration' tab in the left hand menu:-
2017-2-13
x1War Monger1x
Aardvark Posted at 2017-2-13 17:37
Mine doesn't show that stuff. I only have firmware and black box and those are the only two things on the left hand side. The only other thing that I can think of is that I needed to download again and it came up the same exact way the second time. So now I am thinking that it might be a problem with the programming of the mavic itself. I even reloaded the firmware to see if that might make a difference and it didn't.
2017-2-13
x1War Monger1x
maybe they don't have all of that stuff for the Mavic just yet?
2017-2-14
Aardvark
x1War Monger1x Posted at 2017-2-14 04:53
So you download Assistant 2 (PC or Mac ?), and install it, accepting the USB driver pop-up when it appears on screen. Then re-launch Assistant 2, power up aircraft and connect to PC/Mac using USB cable. Click on device icon when it appears on Assistant 2 page, and that should be it.
As you say though, the procedure might be different or not in place yet on Assistant2 to calibrate the 'Sensors' on the Mavic. Or it could be a software/firmware glitch.
2017-2-14
x1War Monger1x
Aardvark Posted at 2017-2-14 05:10
I first downloaded the zip file for PC. Windows based. After installation I started up the program, connected the mavic and the button for RC MAVIC PRO came up. I hit the button and then the next page that came up only had firmware and black box and nothing more. I am an IT person by trade. Cyber Security and all that.
2017-2-14
Aardvark
x1War Monger1x Posted at 2017-2-14 05:32
Have a look at page 23 on the manual , downloadable from Here.
There is also an option to calibrate sensors on Mavic via DJI Go 4. (I wonder if Assistant 2 needs to be run as 'Admin' ?).
2017-2-14
x1War Monger1x
Aardvark Posted at 2017-2-14 06:01
I tried the DJI Go 4 app several times, followed the instructions explicitly and it tells me every time that the calibration failed and need to RETRY. I have tried following the app, then I tried turning the drone at every corner, then the right way and to no avail. I will see if there are other ways to get into the program. I am only able to sign into it by email, and the options are extremely limited. Tonight is a new day right? lol. After work it's game on.
2017-2-14
Aardvark
x1War Monger1x Posted at 2017-2-14 06:12
"Tonight is a new day right? lol. After work it's game on."
That sounds about right
Be sure to check sensor cameras for dust etc.
Try another USB lead as well, just in case.
2017-2-14
x1War Monger1x
Aardvark Posted at 2017-2-14 06:25
I am going to also try deleting all of it, on the phone and the PC. Reinstall and start fresh.
2017-2-14
x1War Monger1x
http://forum.dji.com/forum.php?m ... &fromuid=555537
2017-2-14
x1War Monger1x
new firmware update, definitely doing this when I get home.
2017-2-14
Basin S.
Ukraine
Help me please. Once i've did calibration. May be i did it wrong, but my phantom start to ask me calibrate it. I start DJI Assistant 2 and button START is not active.
2017-2-19
Basin S.
Ukraine
Sorry. I download Assistant for Phantom 4, not for pro. But i think they are similar
2017-2-19
Basin S.
Ukraine
I dont know what happening, but I connect my phantom and do calibration operations. BUT... on 90% it freeze! Im waiting about hour and close the application. Try to start again and same problem. WTF?
2017-2-19
Aardvark
Basin S. Posted at 2017-2-19 09:44
WTF ?
Why The Failure ?
Presumably you're using the latest version of DJI Assistant 2(V1.0.9) to calibrate the sensors on your P4. It seems odd that it's accepted the calibration input (lining up the blue squares, and then sticking on the final calibrate bit. Is there another computer you could try it on ?
2017-2-19
Basin S.
Ukraine
Aardvark Posted at 2017-2-19 10:06
WTF ?
Why The Failure ?
I dont know why, but after restarting, rebooting etc my operation of calibration successfully done. BUT. In DJI GO still see that
2017-2-19
Aardvark
Basin S. Posted at 2017-2-19 10:30
I dont know why, but after restarting, rebooting etc my operation of calibration successfully done. BUT. In DJI GO still see that [view_image]
If you're using a Phantom 4 try moving to DJI Go 4 and see what that reports. DJI Go 4 is the way forward for the 4's, Mavics & Inspire 2 etc.
I believe the Phantom 4 and the 4 Pro versions of Assistant 2 to be the same file, but there may be a chance there are differences between them.
2017-2-19
Basin S.
Ukraine
I dont know why, but now i try to run phantom, and this message is gone
2017-2-19
Basin S.
Ukraine
Aardvark Posted at 2017-2-19 12:46
What interesting...
After some time i once more start phantom and rc and have no any messages in DJI GO. I don't know why it happening (
Thanks for help. Now everything is fine )
2017-2-20
WOLF71
Mexico
Hi, I'm having the same problem!!!
all happened after I did the last update.
started to appear the vision sensor calibration error.
I did everything and nothing work.
calibration with dji 2 assistant nothing showed on the screen only a blank screen.
so then I crashed when I'd test the mavic, nothing serious but it did not respond at all.
2017-2-24
fansb14b3d72
Flight distance : 11362310 ft
i couldn't get this to work.    .    . until i stopped trying on my imac and used a pc labtop. worked 1st time!
2017-3-7
Sloan Fischer
Did you update? Is your camera hanging freely?
2017-3-7
12Next >
