Random problem with VPS P-Opti in the Inspire 1 V2.0
1688 1 2016-4-3
curso88
Flight distance : 184852 ft
Some times, when turn on the aircraft, in good light conditions and in a pattern surface, the optical system of the VPS not works, the app sow ATTI mode. When I restart the aircraft, the problem disappears, and the P-Opti works well. I do not know if this issue Is from a firmware bug or hardware problem.
Is a firmware bug or hardware problem?
Video of the problem:
https://youtu.be/HrSiBWJiP_U
All firmware is up to date
Firmware versions:
App: Version 2.7.1
Aircraft: Version 1.6.00.40
RC: Version 1.5.80
Camera: Version 1.7.00.90
2016-4-3
curso88
I have managed to reproduce the problem in my Inspire 1 V2.0  To reproduce this issue or bug first connect your RC and app and your Inspire 1. Exit from travel mode, turn off the aircraft to place your camera. Turn ON the aircraft and check it that all is correct. If you not have GPS signal the Inspire 1 automatically activates the optical VPS and you can see in the app Mode: P-Opti with two green flashes in the rear light status of the craft.  Now, you can reproduce the problem if you press the preview button in the RC. Immediately a message appears on the application DJI GO indicating that the craft are in ATTI mode. The app indicates Mode: ATTI and the light of the rear craft are a a yellow pulse.  You can see this firmware or hardware bug in this video. https://youtu.be/WtMoh3pDNbM  Best regards
2016-4-4
