Battery Problem
890 4 2016-4-3
markhowerton1
I didnt find this in a search. I charged the battery then was going to setup the phantom but realized I didn't have a compatible device.  Ran the battery down to 50% just letting it set with the lights on.  Charged it again and setup the phantom.  When I opened DJI assistant hooked to my P4 I just got the spinning cursor and wasn't sure if it was updating or lockied up.  I let it run abut 40 min. and the cursor was still spinning.  Stopped the job and when I went to charge the the battery it appeared to charge for a minute or 2 then shut off.  I put it in the P4 and it doesn't  recognize it.  The P4 doesn't even turn on with that battery.  My other battery is OK.  Was it updating and I messed it up.
Mark
2016-4-3
DJI-Paladin
Flight distance : 2408 ft
Hello, do the assistant 2 work well with other battery? And is this battery fully charged now?
2016-4-5
markhowerton1
DJI-Paladin Posted at 2016-4-5 05:31
I haven't hooked it up to the DJI assistant since it quit working but the battery will not charge.  At work any suggestions to try when I get home.  If not I need to send the battery back.
Mark
2016-4-5
DJI-Paladin
markhowerton1@y Posted at 2016-4-6 02:42
I haven't hooked it up to the DJI assistant since it quit working but the battery will not charge. ...
Before charging the battery, I‘d suggest you to plug the charger into the socket at first. Then try to charge the battery for 40 minutes or 1 hour. If the battery does notwork, please contact our NA office and here is the contacting info:
Email: support.us@dji.com
Phone: +1 (818) 235 0789
Mon-Fri 9:00 am - 5:00 pm (PST)
2016-4-5
markhowerton1
DJI-Paladin Posted at 2016-4-5 23:14
Before charging the battery, I‘d suggest you to plug the charger into the socket at first. Then t ...
Thanks. I contacted them yesterday.
Mark
2016-4-6
