Tablet compatibility of P4
1088 6 2016-4-5
k.lower
Can anyone recommend a tablet or smart phone that is compatible with the P4's "follow me " mode.
I had a P3 that work well with a Lenovo 7" untill they updated the software, then only my Samsung GS6 would work in "follow me " mode.
Now nether works with the P4's fm.
2016-4-5
FatedFilmsNC
As I understand it, your asking the wrong question. If i'm getting this right, the "follow me" feature uses cellular signal, which the "Active Track" feature uses GPS and sensors. I was told by a DJI rep that basically unless i bought a tablet that has 3G or 4G or an ipad with cellular capabilities I couldn't use the "follow me" feature. He said I shouldn't worry though, because I could use the "Active Track" feature and that basically AT blows FM out of the water.
2016-4-5
DJI-Paladin
Flight distance : 2408 ft
Hello, here is the compatible devices list. If you need the FM function, it would be better to buy a tablet with GPS module like cellular iPad series below 兼容列表.JPG
2016-4-5
RedHotPoker
Flight distance : 165105 ft
iPad Air 2 64Gb Cellular... It's a dream device.
RedHotPoker
2016-4-5
k.lower
DJI-Paladin Posted at 2016-4-6 02:42
Hello, here is the compatible devices list. If you need the FM function, it would be better to buy a ...
Is the Google Nexus 9 compatible with the FM  function
2016-4-6
DJI-Paladin
k.lower@hotmail Posted at 2016-4-6 21:49
The Follow Me mostly depends on the environment and device GPS signal strength. If it doesn't work, the APP will prompt up a message on the screen
2016-4-7
k.lower
DJI-Paladin Posted at 2016-4-7 10:38
The Follow Me mostly depends on the environment and device GPS signal strength. If it doesn't work ...
That was true of the P3. But I get no prompts on the P4. I would like to know if anyone has run the FM successfully and what device they used.
2016-4-7
