Geebax
fans5d0461da Posted at 1-5 17:07
Hi I hope this gets through to someone who might know my problem A few things. RTH does not work yet I have everything you should have switched on for it. I press for three seconds but it stays outcthere. I mean waybout there .. I am not within the range of it being to close. Also it only does the 30 meter height .. no higher. Almost like beginners mode but it is not. As I have that switched off. And lastly in GPS mode it keeps switching to Atti mode on its own. As soon as I reach that height of 30 meters. It’s driving me crazy but gives me good practice in flying I Atti mode but I don’t want to fly to far away in fear of it not coming home. Plus the height is very unsafe. I actually hit some lights in a Footy field because it was so low it did a crazy spin to the ground but I pushed up on left lever and it pulled out of spin. It is a Phantom 3 pro. You can email at RockinRick @shaw.ca thank you
With regard to the 30 Metre bit, you probably need to login to the DJI site to get rid of the restriction. As to RTH not working, you also say it is in ATTI mode. If that is the case, it will not RTH while in ATTI mode. If it is switching to aTTI mode by itself, pay attention to the screen, it is most likely warning you of a compass error. And that error is most likely caused by you switching the aircraft on and lifting off from a concrete surface. If that is the case, you need to move away and place trhe aircraft on grass when you switch it on.
