Eirlink
note: Advanced Parameters only affect GPS Mode
I: The 'I' setting is meant to be used for forward flight when there are head winds and tail winds, increasing the parameters for strong head winds and decreasing them for strong tail wind. Personally I do not recommend flying multirotors in strong winds of any kind, so for me this setting is redundant.
V-Damping: Velocity damping concerns how quickly or slowly the brakes are applied when you stop descending or ascending. You increase the value if you want your multirotor to stop more quickly or sharply.
Disturbed Gain: This supposedly increases the aggressiveness of Position Hold when increased.
NB: Again, I never touch any of these advanced settings, and even the basic settings will be good for most at the default setting. If all else fails and you feel you've got lost with your own settings, reset everything to default and start again. To be honest, for most people you will not notice much difference between default settings and your own tweaks, unless you tweak your multirotor out of control. |
