NEW FIRMWARE INSPIRE 1 PRO + RAW
2119 5 2016-4-7
Joko
Flight distance : 497674 ft
Switzerland
Hi, new firmware available for Inspire 1
http://www.dji.com/product/inspire-1/info#downloads
and Inspire 1 PRO / RAW
http://www.dji.com/product/inspire-1-pro-and-raw/info#downloads
Here the Release Notes:
1. Firmware upgraded to v1.8.1.00
2. DJIGO Android upgraded to v2.7.2
Major Updates
1 Improved encryption to enhance security during transmission. Both the Aircraft and the remote controller must be upgraded or else they will not link.
2 Fixed the issue of batteries over-discharging when stored for extended periods of time (over 90 days)
3 Fixed the issue of Landing gears lowering in midair on rare occasions.
4 Improved stability for camera.
5 Optimezed gimbal parameters.
Note
Be sure do upgrade the Aircraft before upgrading the remote controller, otherwise the Aircraft may not able to exit
Transport mode properly........
2016-4-7
terrylewis
Flight distance : 3517287 ft
Thanks joko,
Appreciate the heads-up!
2016-4-7
Nigpd
Flight distance : 597677 ft
I still haven't updated to the last firmware because of all the ensuing shenanigans, so I will be leaving this well alone until all the inevitable bugs have been ironed out
2016-4-7
gregdavis
Flight distance : 83146 ft
Joko,
Are you sure there is a firmware update for the Inspire 1 RAW?  Both the links you gave only had an upgrade for the Inspire 1 Pro.
2016-4-7
cinematic_aero
Flight distance : 540331 ft
gregdavis Posted at 2016-4-7 21:33
Joko,
Are you sure there is a firmware update for the Inspire 1 RAW?  Both the links you gave only h ...
Inspire 1 RAW firmware now appears to be listed...
Inspire 1 RAW Firmware v01.08.00.90 04-07-16 is the date on the listing. Guess it took them a little longer to get it up there.
2016-4-7
Joko
gregdavis Posted at 2016-4-8 09:33
Joko,
Hi, yes I am, if you don't see the Raw update try refreshing the page...
Bye
2016-4-8
