Kneepuck
Flight distance : 275105 ft
As was mentioned above, just set max height to 500 meters. This will allow you to fly 1640 feet above home point. As long as your height is no more than 400 feet agl, you are fine. But if the mountains are more than 1640 feet above you, you are out of luck. You will not clear them. The faa rule applies to agl, not altitude. |
