silencedk
Denmark
Hi.
Up until today I had a perfectly working P3 adv.
THis morning when I decided to update the firmware to the newly realeased 1.8.8 it all went wrong.
First time I tried the update it went on for about 4-5 minutes, then stopped...
I tried redoing the update severeal times (I think 10 times by now.), all with different combinations of SD cards, remote on/off. and lots of other combinations.
The P3 is all dead now. If I turn it on it beeps two short beeps, pause then two shot beeps..and this goes on, the wing LEDS dont flash. BB--BB--BB--BB
If I open the GO app it says that firmware is up to date which i doubt looking at the log file, but it also cant display battery level anymore. Says "cant connect to flightbattery".
The motors wont start either.
Any help appreciated?
The logs look like this...
Packet: P3S_FW_V01.08.0080.bin
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2016.04.09 11:38:40 =====================
Result: Failed.
========== 2016.04.09 11:53:33 =====================
Result: Failed.
========== 2016.04.09 12:11:46 =====================
Result: Failed.
And the hidden og file like this..
[00011957]========== 2016.04.09 11:03:17. boot(15) ============
[00012002]Packet [C:\P3S_FW_V01.08.0080.bin] detected, card sn [0x0b900ce9].
[00012047]Packet upgrade start...
[00012093]Packet checking...
[00012138]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012184]Record vlink 01.07.0060 <-> 01.06.0040 (flow = 0).
[00012230]Done.
[00012275]Version checking[1]...
[00012359][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012440][03 06][00] v2.4.13.0 -> v2.4.14.5 need upgrade.
[00012491][04 00][00] v1.41.0.0 -> v1.44.0.0 need upgrade.
[00012639][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00012734][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012839][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012939][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013036][12 03][00] v1.10.0.0 -> v1.10.0.0
[00017583][15 00][00] v1.1.2.0 -> v1.1.2.0
[00017667][17 00][00] v1.1.1.7 -> v1.1.1.7
[00017785][17 01][00] v1.0.2.7 -> v1.0.2.7
[00017855][19 00][00] v255.255.255.254 -> v1.0.8.96
[00017901][01 00][00] v1.23.4920 -> v1.23.4920
[00017951][01 01][00] v1.23.4920 -> v1.23.4920
[00018005][09 00][00] v2.13.0.0 -> v3.0.0.10 need upgrade.
[00018049]Done.
[00020094]Waiting for user confirm...
[00030139]Timeout, start upgrade automatically.
[00030226]Firmware upgrading[1]...
[00030281][11 00] Firmware upgrade start...
[00077717][11 00] Firmware upgrade finished successfully.
[00077938][03 06] Firmware upgrade start...
[00359410][03 06] Firmware upgrade finished successfully.
[00359485][09 00] Firmware upgrade start...
[00412865][09 00] Firmware upgrade finished successfully.
[00412934][04 00] Firmware upgrade start...
[00470991][04 00] Firmware upgrade finished successfully.
[00471036]Done.
[00471083]Version checking[2]...
[00483631][03 05][00] device not detected.
[00496176][03 06][05] device not detected.
[00496360][04 00][05] v1.44.0.0 -> v1.44.0.0
[00508907][11 00][05] device not detected.
[00521456][12 00][00] device not detected.
[00534001][12 01][00] device not detected.
[00546547][12 02][00] device not detected.
[00559095][12 03][00] device not detected.
[00559145][15 00][00] v1.1.2.0 -> v1.1.2.0
[00571694][17 00][00] device not detected.
[00584241][17 01][00] device not detected.
[00584304][19 00][00] v255.255.255.254 -> v1.0.8.96
[00584355][01 00][00] v1.23.4920 -> v1.23.4920
[00584404][01 01][00] v1.23.4920 -> v1.23.4920
[00584464][09 00][05] v3.0.0.10 -> v3.0.0.10
[00584514]Packet upgrade failed at version checking.
[00012016]========== 2016.04.09 11:15:22. boot(15) ============
[00012064]Packet [C:\P3S_FW_V01.08.0080.bin] detected, card sn [0x0b900ce9].
[00012111]Packet upgrade start...
[00012163]Packet checking...
[00012206]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012253]Record vlink 01.07.0060 <-> 01.06.0040 (flow = 0).
[00012301]Done.
[00012349]Version checking[1]...
[00024897][03 05][00] device not detected.
[00037444][03 06][00] device not detected.
[00037499][04 00][00] v1.44.0.0 -> v1.44.0.0
[00050050][11 00][00] device not detected.
[00062596][12 00][00] device not detected.
[00075143][12 01][00] device not detected.
[00087689][12 02][00] device not detected.
[00100237][12 03][00] device not detected.
[00100285][15 00][00] v1.1.2.0 -> v1.1.2.0
[00112834][17 00][00] device not detected.
[00125381][17 01][00] device not detected.
[00125456][19 00][00] v255.255.255.254 -> v1.0.8.96
[00125505][01 00][00] v1.23.4920 -> v1.23.4920
[00125556][01 01][00] v1.23.4920 -> v1.23.4920
[00125615][09 00][00] v3.0.0.10 -> v3.0.0.10
[00125662]Packet upgrade failed at version checking.
