Camera vibration
1194 4 2016-4-11
juansantiuste
Last time I was flying I experienced some strange image vibration in the recording... In the previous flight with another battery in te same place minutes before it didn't happened. I haven't had opportunity of flying after, son i can't see if it continues. I used later the camera on Osmo without issues. It was a little windy but no too much. It seems to vibrate somtimes when the aircraft stops or begins movement.. I have revised camera mounting plate and didn´t nocticed something. Is an I1 v1 with X3.
2016-4-11
DJI-Tim
Your video is private, can't watch it
2016-4-11
juansantiuste
Ok, I don't know why it wasn' published yet, but I could watch it... I hope is OK now, thanks!
2016-4-12
DJI-Adela
The video works now.
Did you try to calibrate the IMU and the gimbal? If that didn't work for you, you'd better return your unit for a check. It seems there's something wrong with the hardware.
2016-4-12
juansantiuste
OK, I will update firmware and do IMU and gimball calibratio, and see wehat happens. Tanks!
2016-4-15
