johnsr
Flight distance : 1579022 ft
Yes, there are a number of ways to get better control for filming.You can find the gain and expo settings in the MC settings menu > Gain & Expo tuning. You can start by reducing the Yaw (rudder) expo to its minimum value (0.20), many also do the same with the Forward/Backward/Right/Left setting. (see photo). It is not recommended to drastically change the gain values, as these control how the Phantom reacts to external forces (down to 0.80 is OK). You can also lengthen the sticks for better control (if you look closely you will see that they are adjustable, each with a lock screw ). Lastly, have a look at the Gimbal menu > Advanced settings; adjustments here will smooth the gimbal response (I suggest that you modify these parameters with the Phantom setting on a table and see what they do for you).
Have fun & good flying!
