rodger
Flight distance : 20145135 ft
If you are using a MAC it is a simple project with the Fade part. Use Keynote. There are a ton of transitions that will do that and you can set the amount of time for the fade to disappear and the next shot reappear. Use the Inspector and adjust your Photos to your liking. Use Tim's suggestion for setting the waypoints and everything should work out nicely. |
