jstjohnz
Flight distance : 1146388 ft
The problem is that the rules, as they are now, lump all hobby RC craft together. For traditional non-FPV equipped fixed wing or single rotor hobby aircraft flying LOS is pretty much mandatory. If you lose sight of it you will probably crash it. Modern 'smart' multi rotor aircraft with GPS, hands-off hover, RTH, and FPV are a completely different beast.
Unless the aircraft is very close, determining what's directly under you without FPV is difficult. With FPV, click gimbal down, and you immediately know exactly where you are. Also, when you have a non-FPV craft, you are always looking at it so maintaining constant LOS is fairly easy. When you add FPV, every time you look at the screen, and what's the point of having FPV if you don't?, then it's going to take you some period of time to visually re-acquire the aircraft. Is that considered "maintaining LOS"?
I personally feel that flying FPV is much safer. Not only do you have a map and camera view for location determination, you can determine the height of objects around you by running the gimbal to horizontal.
If you fly a FPV multi-rotor with RTH capability at a sufficient altitude to clear objects and terrain, it's going to take a mechanical failure or a bird strike to cause a crash.
Ask yourself this: what do you do if you lose visual of your aircraft? Most pilots will look at the screen to determine relative bearing, altitude, and range to know where to look in the sky.
