Geebax
Not all tablets even have a GPS fitted to them, the non-cellular iPads for example don't have a GPS at all. So if you want the follow me function to work, then it is essential that your tablet has a functioning GPS because it is how the aircraft knows where you are. The tablet may work fine with the DJI Go App, but that does not mean it can access the GPS data from the tablet.
The follow me function is a very complex one, and if the GPS data is not strong and clear, you may not get it to work at all. I know you don't want to hear this, but you probably will have to buy another tablet if you want to use this function. If you do, then select from the recommended list on the DJI site.
EDIT: I just looked up the Nextbook Ares 8, and in the specs it does not even mention that it is fitted with a GPS receiver, so it most likely does not have one.
