Suggestion to DJI
1365 17 2016-4-12
jerryjonz
When you bring up DJI Go to the "Connect your DJI device" screen you have to change to the correct device every time.
With one line of code in the file you could make the program save the last used device.
It could easily be changed if desired.
I have probably gone through that screen over 100 times with all the update hassles.
It would save your users a whole lot of trouble and time.
Hope you implement this and soon.
2016-4-12
jerryjonz
Make the ABOUT screen on the RC show the last reported firmware level for the flight controller, and
the present level of the RC when the P3P is turned off.
Presently it says N/A.
The RC firmware level should be available to the RC.
2016-4-12
microcyb
Flight distance : 1095955 ft
Mine always goes to my bird so odd others do not.
2016-4-12
jerryjonz
Add the Nvidia Shield K1 to your compatible list.
It is one of the fastest tablets available.
It has the NVIDIA Tegra® K1 processor which features a 192-core NVIDIA Kepler™ GPU and 2.2 GHz quad-core CPU.
2016-4-12
DJI-Tim
What mobile device are you using? My DJI GO also recognizes correct drone every time even i'm using different models.
2016-4-12
jerryjonz
I have the Nvidia shield K1.
It have not been working since update 1.8.80, I have no video and disconnected.
When I update I have video until I power off/on, then no video and disconnected.
I can fly just fine.
2016-4-13
jerryjonz
Do NOT ban anyone, it looks bad on DJI.
Like NO free speech on this site.
2016-4-13
mlpdx
I agree it is odd that the DJI Go app does not remember what you connected to last, but I have never bothered selecting the aircraft -- it always shows an Inspire 1 in the dropdown list, but connects to my Phantom 4 just fine, and shows the Phantom 4 automatically after it connects.   Is this not true of other models?
2016-4-13
jerryjonz
Identify every post as to Apple or Android tablet or phone.
Seems like the issues for each is different.
2016-4-13
jerryjonz
Allow RC calibration with P3 offline.
2016-4-13
jerryjonz
Make an Apple forum and an Android forum.
With all planes under those.
2016-4-13
Geebax
jerryjonz Posted at 2016-4-14 08:16
It does not need to be added as a feature, most people's devices recognise the aircraft correctly every time they switch on. Your case is an exception, not the rule. What order do you power up the system? It works for me if I switch on the aircraft fist, then the RC unit, and the tablet then switches on automatically.
2016-4-13
jerryjonz
Hi Geebax
Which entry are you referencing?
2016-4-13
jerryjonz
add a SUGGESTION tab somewhere
JDJ
2016-4-19
jerryjonz
Make the password autofill
delete the extra login step
2016-4-19
jerryjonz
add a search function
2016-4-19
jerryjonz
put identifier in each update that will identify target ship, then don't let the installer install if
the correct type is not correct. This is standard a programming practice.
2016-4-19
jerryjonz
Don't allow shutting motors off if at altitude
2016-4-26
