Set Home on DJI go APP 2.7.2
1624 12 2016-4-14
nicolas.w.roth
Flight distance : 28556 ft
Switzerland
Hello,
does anyone knows what are the changes with regard to the "Home setting" function on the 2.7.2 DJI go app?
first I am confused because previoulsy it was very conveniently located on the main screen and now i cannot find it
thanks
nico
2016-4-14
terrylewis
Flight distance : 3517287 ft
Main Controller Settings (MC Settings)
They may not show untill things are powered up....
2016-4-14
Aardvark
Flight distance : 384432 ft
You can choose to make home position the current position of either the aircraft OR the Remote Control. If no GPS signal (i.e. indoors) then it will 'fail' to set home position.
2016-4-14
terrylewis
Aardvark Posted at 2016-4-15 03:00
You can choose to make home position the current position of either the aircraft OR the Remote Contr ...
Thanks Aardvark. To expand the information in your post.
Since the P3 RC does not have GPS to establish its location, your mobile device must provide the location to the GO App to be able to set the RC location as your new home point...
2016-4-14
SajidShah
Flight distance : 627539 ft
Portugal
Nice info Mate
2016-4-14
Rnfaust
Flight distance : 734938 ft
FYI: resetting the Home point after takeoff does not reset (zero out) the altitude established at the original takeoff point. You are resetting the home point mid air after all.
2016-4-14
madaerial
Flight distance : 512251 ft
Aardvark Posted at 2016-4-14 14:00
The arrow is the craft right? And the person the remote?
2016-4-14
terrylewis
madaerial Posted at 2016-4-15 04:20
Correct....
2016-4-14
windgate
Aardvark Posted at 2016-4-14 15:00
...so if you are flying either with an iPad that does not have mobile connectivity or you have data services and GPS turned off on your phone/mobile device -- then would it not be possible to set Home as the RC?
2016-4-14
nicolas.w.roth
Switzerland
windgate Posted at 2016-4-14 22:37
...so if you are flying either with an iPad that does not have mobile connectivity or you have data ...
thanks for your replies guys
2016-4-14
Daninho
Flight distance : 70203 ft
I dont have an Ipad with build in GPS but it still shows that icon, strange.
2016-4-14
ISA AYDIN
Flight distance : 504692 ft
This was always there, I used it when P4 was just released. What is the update about, then. Also this setting works only with cellular devices which have GPS. Wont work with iPad Wifi
2016-4-14
rodger
Flight distance : 20145135 ft
Daninho Posted at 2016-4-15 02:32
The Lat and Long are established by a Cellular or Wi-Fi connection.
2016-4-15
