Gimbal shifted slightly to left ...
dobmatt
Flight distance : 1831050 ft
Is it the issue of this tiny set screw on yaw axis not aligned properly, or something else? I performed gimbal calibration, set the mode to FPV, but it didn't help much.
2016-4-15
seth.feingersh
Flight distance : 254639 ft
bump here. My P3P has a bit of a shift to the left as well. Any help?
2016-7-4
dobmatt
seth.feingersh@ Posted at 2016-7-5 00:25
I believe it's a birth defect of P3P, seen this on many other ...
2016-7-4
shayanza
If the gimbal calibration doesn't work, you can always adjust the gimbal manually in the DJI Go App. I always felt like my gimbal was off by the slightest amount so I just adjusted it that one time manually and now its fine
2016-7-5
seth.feingersh
shayanza@usc.ed Posted at 2016-7-5 23:09
If the gimbal calibration doesn't work, you can always adjust the gimbal manually in the DJI Go App. ...
Only seeing the ability to adjust roll, not yaw
2016-7-5
dobmatt
seth.feingersh@ Posted at 2016-7-6 02:09
yep, that's correct: only horizon adjustability, not YAW zeroing ...
2016-7-5
