I have a problem, I installed 2 batteries on my Matrice 100, but he used only one battery and then he landed because battery went out but other battery was ok.
If the battery which is connect to the Flight Controller is working OK, the Matrice 100 will be still under control.
If the other battery is powered off, just remember to unplug the cable to avoid short circuit.
Hi,
Could you please confirm if the battery connected to the center plate run out of power or the external battery? Have you noticed any LED abnormal indicator?
please check the battery connection.
yes, battery is connected to the center plate, and other is also connected to other connector. But as I said before, I just connected battery, without turning other battery on, I just turned the main battery on.
