Suddently i have no FPV, it worked 4 mds ago, and craft have no crash.
All telemetri, and groundstatin works, it can film at take pictures on SD.
I have tryed to reinstall app (different versions), rebind - but no FPV.
What could be wrong ?
Check cables around gimbal, known to be finicky
Wifi module is possibly gone in the bird
Do you have a range extender?
Are you on iOS or Android?
There have been an android update that bricked a lot of the RE's
Thanks for reply.
All cables is checked, and yes i have range extender and i guess if it was dead, i would not have telemetri - but all works, tilt camera, radar, goundstation and so on.
I am on Android, and have NOT updated anything, my internet connection is cancled to prevent any aut, updates
There's a known issue with the wifi modules on Phantom 2 Visions. It stops xmitting the video but the telemetry still works and you can record video and photos.
BWJ Posted at 2016-4-17 03:27
Thanks for reply.
All cables is checked, and yes i have range extender and i guess if it was dead, i ...
The wif transmitter in the Phantom itself contains two PCB boards. One for telemetry and the second is video. The video board have had some issues in the past and have burned out.
Try these and if none work the video is most likely out.
Video feed trouble shooting
Please try the following steps:
• Ensure you have upgraded all DJI products to their latest firmware. Check updated, plus the camera firmware
• Ensure you are connected to the wifi phantom-xxxx SID
. Check bluetooth be sure it is off
• Ensure your phone has been updated to the latest software.
• Ensure you have closed all other multi-tasking applications.
• Check the free space on your mobile device, it is recommend having at least 3GB available, less storage could be causing an issue.
• Try deleting the app from your phone and downloading it again.
Try reformatting the SD card with full format.
• Reduce the preview framerate from 30 fps to 15 fps in the Settings of the DJI Vision app.
Check your wifi battery level.
Check the three leads going to the gimbal to be sure they are tight. Check each one closely for any pins that may have pulled up and loose.
If the above don't get it then the only remaining check is the video feed plug on the wifi transmitter under the shell.
If that's ok then it's most likely a damaged or burnt out wifi transmitter if you still see the SID.
I had the same issue no telemetry and video from my unit. Turned out to be the gopro update, it killed the USB video out. I returned it and did not do the update on the gopro and everything worked ok after that. Did you do the update on your gopro?
