Inspire not lowering the landing gears
1827 3 2016-4-17
pieter.splietho
Please help me, I'm a new user for the inspire 1, I had two times a problem with the landing gears when I start for landing.
The Go app says "landing gear lowering" but the inspire stay the landing gear up!
Can anybody tell me what is going wrong? The landing gear works perfectly when I use the travel mode or out of the travel mode.
Thanks for helping me
2016-4-17
terrylewis
Flight distance : 3517287 ft
Pieter,
    When the GO App is configured for automatic landing gear raising and lowering, the VPS altitude governs when the gear actually lowers, so try two things for troubleshooting:
1) Try gently flying the I1 lower to it's landing location and see if the gear lowers.
2) Try manually lowering the gear by toggling the transformation switch and ensure that the manual mode works.
2016-4-17
Aeromirage
Flight distance : 1778045 ft
Ever since I did the last FW update I have had to manually lower the landing gear on mine. It is a V 2.0 and when I take off they raise up on their own. When landing I have to get within 2 feet of the ground before they will self lower. Turning the switch around the RTH button does lower them, but the self adaptive feature seems to be out of sync. They used to self lower at about 8 or 10 feet from the ground.
2016-4-17
pieter.splietho
terrylewis Posted at 2016-4-17 09:12
Pieter,
    When the GO App is configured for automatic landing gear raising and lowering, the VPS a ...
Thanks for your information.
I'll appreciate it.
2016-4-17
