ATTI and GPS mode, RTH
943 5 2016-4-17
kcmusa
Flight distance : 132067 ft
Want to be sure I am clear on this before I get myself in trouble.
I know GPS mode will returen to home if signal lost, what about ATTI mode?
If signal is lost in ATTI mode, does it RTH or just hover in place till low battery?
2016-4-17
Kneepuck
Flight distance : 275105 ft
So long as you have gps connection, the Phantom will use gps to return to home, even if you manually select ATTI mode.
2016-4-17
classic2003
Flight distance : 632769 ft
What is the purpose of ATTI mode?
2016-4-17
Nink
classic2003@sym Posted at 2016-4-17 14:07
Gives the pilot better control of the drone, ideal when filming in doors or tricky conditions without trying to autoposition.  Example flying over snow or water the quad gets messed up when trying to lock onto a pattern so ATTI mode gives you control. It will go into ATTI mode when it doesn't have a GPS signal.   What I don't like about ATTI mode is it still has Hover stabilization so it will auto level when you let go.  They really need to have a mode that allows pilot full control and turns off auto level.  This way you could get some amazing shots in FPV mode upside down,  flips, rolls etc
2016-4-17
helidan
Flight distance : 459951 ft
Don't think aerobatics are the Phantoms thing to be honest.  You want footage like that get a FPV racing quad.
2016-4-17
DJI-Paladin
Flight distance : 2408 ft
In ATTI mode, if the GPS signal is strong enough and home point is recorded, the drone can use RTH.
2016-4-17
