New footage with variable ND filter
12Next >
2498 44 2016-4-18
stalked-buddha
Banned
2016-4-18
scarper
Flight distance : 59272 ft
How does it compare to our footage without?
2016-4-18
Rnfaust
Flight distance : 734938 ft
Beautiful footage.
What is a variable ND filter?
2016-4-18
phantom-four.co
Croatia
Rnfaust Posted at 2016-4-18 17:46
Beautiful footage.
Simple explanation variable ND filters cover multiple ND stops depending on how it's set up by turning the first part of the filter
Edit: longer explanation
2016-4-18
stalked-buddha
Banned
2016-4-18
stalked-buddha
Banned
2016-4-18
Aardvark
Flight distance : 384432 ft
phantom-four.co Posted at 2016-4-18 17:29
Simple explanation variable ND filters cover multiple ND stops depending on how it's set up by turn ...
So it's a polarised filter, which is not an ND filter.
2016-4-18
jyurkyandsons
Aardvark Posted at 2016-4-19 01:41
Sounds like you might be able to tell me what's the best setup for a ND8 /CP filter P3series?
2016-4-18
Aardvark
I don't have sufficient experience regarding the Phantom filters, I have never bought filters for the P3. Only based on previous use many years ago on SLR.
If you do a search (click on magnifying glass at top of page ) there are many threads advising choices.
2016-4-18
stalked-buddha
Banned
2016-4-18
Show Me Drone
I was thinking the exact same thing .     I am of the belief that a ND filter is fixed and a Circular Polarizer can be rotated .     I read a long time ago that the best effects from a Polarizer come at a 90 degree angle from the sun .   So  use your thumb and pointer finger  , make an "L" with them  ,Point at the sun with your finger and whichever direction your thumb is pointing would be the greatest effect of it ( The polarizing filter )
2016-4-18
markbaines2000
Flight distance : 685951 ft
That's good someone else in Sheffield you have just given me some great places I can go when my p4 arrives
2016-4-18
phantom-four.co
Croatia
Aardvark Posted at 2016-4-18 19:41
It's two polarised filters. One circular (front) and one linear (rear)
2016-4-18
Aardvark
stalked-buddha Posted at 2016-4-18 19:20
No its a neutral density filter which limmits the light hitting the sensor a polariser reduces the ...
It seems I'm missing something, but OP had posted a link to an explanation of what a 'variable ND' filter is, and there it quite clearly states :-
"How does it work? This method uses the properties of polarised light, specifically that two parallel polarisers will block very little light but two at 90 to each other will block nearly all light travelling through them. Find out more about polarisation, including in photography, here. This variable neutral density filter is far from perfect, but great if you want to make one cheaply!"
2016-4-18
phantom-four.co
Croatia
Actually, it was not OP that posted
And although I accidentally posted the wrong link (too many photography bookmarks), yes. 2 Polarizing filters are used to make a variable ND filter. Does that make it a polarizing filter? No, the end result is different. Kinda like "a house is made of bricks but a house is not a brick" (for lack of a better analogy)
2016-4-18
stalked-buddha
Banned
2016-4-18
Alan Guan
Banned
2016-4-18
stalked-buddha
Banned
2016-4-18
Aardvark
Yes, and apologies for detracting from that, but the term  'variable ND filter'  irked me a bit. Do you have a link to filter you are using ?
Regarding the video, was the camera on auto exposure ? I noticed one or two moments where the exposure values switched suddenly.
2016-4-18
stalked-buddha
Banned
2016-4-18
stalked-buddha
Banned
2016-4-18
stalked-buddha
Banned
2016-4-18
mrbillgill1
Flight distance : 717100 ft
Aardvark Posted at 2016-4-19 00:26
Yes, and apologies for detracting from that, but the term  'variable ND filter'  irked me a bit. Do  ...
Variable nd filter is a standard industry term for a standard industry bit of kit. Some vari-ND's are expensive and have little effect on color balance. Some cheapies cause nasty shifts to green and introduce 'cross hatching' patterns. I think this one looks pretty good in terms of color rendition.
@stalked Buddha - would you say the general sharpness of your footage is unaffected?
2016-4-18
markbaines2000
stalked-buddha Posted at 2016-4-18 22:46
Give me a shout mark I'm always about for a meet up and a flight
I will mate when I'm ready
I'm new to all this so it may be a while till I get used to all the controls etc lol
2016-4-18
stalked-buddha
Banned
2016-4-18
Aardvark
mrbillgill1 Posted at 2016-4-19 00:54
Variable nd filter is a standard industry term for a standard industry bit of kit. Some vari-ND's a ...
Thank you for the clarification.
2016-4-19
mrbillgill1
Aardvark Posted at 2016-4-19 10:03
No problem
2016-4-19
rodger
Flight distance : 20145135 ft
Whose Filter are you using?
2016-4-19
rodger
Rnfaust Posted at 2016-4-18 11:46
Beautiful footage.
Very essential. Do some research. You will have to use it in manual mode, the camera that is. I am speaking about still photography. I am not that familar with Video.
I did some shots yesterday in bright sunlight and the DJI camera did an excellent job without a ND Filter.
2016-4-19
rodger
Beautiful footage.
I just noticed that there is a ND Filter Tutorial from a forum member here on the home page.
2016-4-19
Rnfaust
rodger Posted at 2016-4-19 20:07
Very essential. Do some research. You will have to use it in manual mode, the camera that is. I am ...
I keep the DJI ND4 filter on all the time. Of course I'm no pro and I don't fly too early or late. It seems to keep values in line for better videos. I've read that  the filters aren't necessary for stills. I just extract my stills from the videos while editing in Pinnacle. As I said, I'm no pro, just having fun.
The snow can be challenging.
2016-4-19
stalked-buddha
Banned
2016-4-19
stalked-buddha
Banned
2016-4-19
rodger
Rnfaust Posted at 2016-4-19 12:10
I keep the DJI ND4 filter on all the time. Of course I'm no pro and I don't fly too early or late. ...
We all enjoy flying and photography. Great relaxation aid.
2016-4-20
rodger
stalked-buddha Posted at 2016-4-19 16:57
Hi ya Rodger
Like yourself I've had great results from the camera both with and without any filte ...
True on the variable filter. The amount of light passing through changes with the angle. I prefer incident light readings. I use a light meter and put the filter over the meter sensor with the meter and sensor at the same angle that the light is coming from. Of course that is when it is possible.
2016-4-20
rodger
stalked-buddha Posted at 2016-4-19 16:59
Cheap and cheerful neewer filters off of eBay nothing fancy but works a treat
Thanks. Your post was the first that I had heard of a variable ND Filter for the DJI Camera. Now all I have to do  is find a Skylight Filter that fits.
2016-4-20
gtokarsk
Flight distance : 14869882 ft
I almost got me a variable ND 2-400 filter, but for now went with nd4 nd8 and polarized, 3 filters....  I wonder if I will end up with variable as well.. it sounds tempting.... can u tell roughly what value u were dialed in, or u just do a visual check on how you like the video? It does bring out the color and tone in the videos! Not something you could achieve quite as easily in a video editing software, not a free or cheap one, anyhow....
GT
2016-4-20
stalked-buddha
Banned
2016-4-20
stalked-buddha
Banned
2016-4-20
Geebax
stalked-buddha Posted at 2016-4-21 08:15
I generaly set the camera settings by getting the ambient light readings then work from there !
Th ...
If you don't mind the comment, you footage looks to me to be a bit on the dark side. I think you could increase the exposure a little, and perhaps boost the darker areas in post using a good colour grader like Resolve. Being in a northern part of the globe, the sunlight does not impact the ground as directly, so you could help it out a little.
2016-4-20
12Next >
