RC SIGNAL LOST - after upgrade
chrisslemke
Hi all,
this seems to be a common issue but the other threads have not been of help.
Now, following situation:
RC - Upgraded
P3A - Upgraded
Error: RC SIGNAL LOST
Tried linking, no changes
P3A flashes yellow
Camera indicates (doesn't flash) green light
I see the camera view on my ipad
P3A won't arm up engines
RC indicates (doesn't flash) green
Can somebody please tell me that to do to get my P3A back in the air?
Thanks so much
Chris
2016-4-18
alfredodiazm
Flight distance : 389610 ft
Venezuela
Be sure to copy the BIN FILE direct from the UNZIP window. The BIN fie in the SD card must have 63.0MB if not will not work.
2016-4-18
chrisslemke
alfredodiazm Posted at 2016-4-18 19:57
Be sure to copy the BIN FILE direct from the UNZIP window. The BIN fie in the SD card must have 63.0 ...
Thank you so much for your answer. Unfortunately, there have not been changes. The camers light just flashed to red quickly and then remained green. The report is attached.
What else could be wrong?
2016-4-18
djsimul
chrisslemke Posted at 2016-4-18 13:22
Thank you so much for your answer. Unfortunately, there have not been changes. The camers light ju ...
This video might be of help:
Use that method to force the controller to 1.5.80, then allow the DJI GO app to update it to 1.6.0 and you should be good.
I was able to get the RC and craft communicating and can power on the motors now. Good luck!
2016-4-18
alfredodiazm
Venezuela
chrisslemke Posted at 2016-4-18 13:52
you go it....the first report its a SUCESS, that is it!!! ....the next reports its because you leave the P3 on whe the green light with a D..DD sound. That means that the upgrade its done
2016-4-18
alfredodiazm
Venezuela
2016-4-18
alfredodiazm
Venezuela
alfredodiazm Posted at 2016-4-18 15:39
you go it....the first report its a SUCESS, that is it!!! ....the next reports its because you lea ...
If you still have a signal lost, then you must link the RC again. look in the P3 for the two small holes at the same side where the usb cable goes in the gimbal. you will see two small holes far left, turn on the DC and the P3, go to Remote Controller Settings scroll down will see "Linking Remote Controller" click there and pinch with a pencil in the second hole left to right and the  messague RC linked should pop.
2016-4-18
alfredodiazm
Venezuela
Uphs I believe that your did not download the P3X_FW_V01.08.0080.
2016-4-18
chrisslemke
alfredodiazm Posted at 2016-4-18 22:25
Yes alfredodiazm,
I got that as well. I downloaded the P3P firmware instead the P3A.
That's why it didn't work, now all seems fine.
Thank you!!!
2016-4-18
