johnsr
Flight distance : 1579022 ft
ADC means analog to digital converter. Its a component in the electronics chain that converts amplified electronics signals from your camera's sensor into digital information. I mentioned it as a possibility, the next stage in the chain handles the information from the pixels. The problem could happen at one of these lower levels. As the previous poster said, it could be RF interference, so rule that out first. If finally it is a real problem, then yes, a new camera would work, but a repair might be much cheaper (its all on a small PCB in the camera). I would contact DJI.
Note added 25 min later: I checked out the SONY EXMOR R sensor used in the P3P; its a sensor with an on-chip A/D conversion & noise reduction circuits. That means, if ithe problem is real (not RF nor firmware related) the camera's sensor unit would need to be replaced.
