Zenmuse XT
1100 4 2016-4-19
davidherries
Flight distance : 3768451 ft
New Zealand
Hi
Just confirming the radiometric data is stored in the outputed JPEG file stored on the SD card of the Zenmuse XT camera.
Thanks in advance.
Cheers
Dave
2016-4-19
wenong
Flight distance : 221083 ft
The given video recording bitrate is 2Mbps, is the radiometric video lossless?
2016-4-19
Rob W
Flight distance : 94390 ft
Sweden
Is it possible to get data output to a text file? For instance hotspot temperatures for a givetnGPS coordinate?
Example. You fly along a path, and the surrounding and ground temperature are between 10-30 degrees C, and then, at a time, we see a high temperature of 100+ degrees C.
With that data win a text file, we could easily ignore the surrounding low temperatures, and quickly get to know where those hotspots are.
I don't know if this is possible, though. Any ideas? Would it be possible to get that data via SDK and make an app for it?
2016-4-22
davidherries
New Zealand
Rob W check out the upcoming concept app from MapPilot app makers..
https://www.dronesmadeeasy.com/Z ... 6_gimbal_camera.htm
2016-5-2
Rob W
Sweden
davidherries Posted at 2016-5-2 10:22
That'll be awesome! Thank's for the link!
2016-5-9
