johnsr
Flight distance : 1579022 ft
This is not an official list, but its what I used for my P3P last August:
• Torx T6 screwdriver
• Torx T8 screwdriver
• 2mm Allen key or screwdriver
• Standard flat screwdriver & dull table knife (used to lever open body-shell)
• Small flat screwdriver (2.4 or 3mm flat) is used to press-open connector latches
• Small precision Phillips-head screwdrivers (P00, P0 and P1)
• Curved electronics tweezers
I also used a small soldering iron to melt the tips of the rods which hold the LED PCBs on each arm. Not tools, but do work in a well lit corner without distraction. There are about 68 screws to remove & replace. Working with a check list is helpful as you can note details to keep in mind during the rebuild phase.
Have fun! |
