RC Signal Lost message after Firmware Upgrade
2271 12 2016-4-19
mrokay
Flight distance : 2756 ft
Hi there, I flew my bird last week and everything was good. 1.I upgraded the aircraft to the last firmware version v1.8.80 and still got the Signal Lost message.
2. Then I updated the Dji Go App to the last version and Upgraded the RC to V1.6 and still got the SIGNAL LOST message.
3. Then I downgrated the RC to v.1.5.80 and still no changes
Also, when I tried to re-upgrade the aircraft, i got this long/continuous BEEP sound( Not the D-D-D-D beep).
2016-4-19
DJI-Paladin
Flight distance : 2408 ft
Hello, could you post the drone's upgrading log file and a screenshot of the fw version here?
2016-4-20
mrokay
DJI-Paladin Posted at 2016-4-20 06:26
YES, I will do that as soon as possible
2016-4-20
tyler
I am having the same issues with my Phantom 3 after upgrading the firmware yesterday.  RC Signal lost
2016-4-20
mrokay
Also, i am a little bit worrying about something. I inserted the micros with only the .bin file in it. The LED light was flashing RED--GREEN  with the Beep sound then The sound STOPPED with the light still flashing Red--Green. It's been doing it for more than 35min. Should i be worried or let it continue ?
2016-4-20
mrokay
tyler Posted at 2016-4-20 10:40
I am having the same issues with my Phantom 3 after upgrading the firmware yesterday.  RC Signal los ...
This issue is driving me NUTTS bro. I'm going on vacate in 3 weeks and this happens. Thanks God I'm completely covered but It will take awhile to get a replacement. I don't know what to do.
2016-4-20
sidajili
Flight distance : 6033701 ft
Nigeria
mrokay Posted at 2016-4-20 16:42
This issue is driving me NUTTS bro. I'm going on vacate in 3 weeks and this happens. Thanks God I' ...
Try rebinding the RC to the drone after upgrading both to the latest version. If both upgrades were successful, rebinding might fix it.
2016-4-20
mrokay
sidajili Posted at 2016-4-20 12:01
Try rebinding the RC to the drone after upgrading both to the latest version. If both upgrades wer ...
Thanks for the tips. But here's the thing now. I'm upgrading the drone, it's been Beeping ( DD...DD) like that for the past 30min. The battery is getting low. smh. Dji needs to fix this bug asap.
2016-4-20
mrokay
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.06.0040.bin
Upgrading ...
Result: Success.
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2016.03.08 15:12:37 =====================
Result: Failed.
========== 2016.03.08 15:20:38 =====================
Result: Failed.
========== 2016.03.08 15:53:48 =====================
Result: Failed.
Result: Failed.
========== 2016.03.08 18:02:03 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2016.03.08 20:06:20 =====================
Result: Abort.
========== 2016.03.08 20:26:02 =====================
Result: Abort.
Result: Abort.
========== 2016.03.08 21:02:51 =====================
Result: Abort.
========== 2016.03.08 21:03:56 =====================
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:13 remo-con disconnect======
Result: Abort.
Result: Abort.
========== 2016.03.11 01:47:36 =====================
Result: Abort.
========== 2016.03.11 01:57:04 =====================
Result: Abort.
Packet: P3X_FW_V01.07.0060.bin
Upgrading ...
========== 2016.03.18 02:42:54 =====================
Upgrading ...
========== 2016.03.18 17:58:16 =====================
Upgrading ...
Upgrading ...
Result: Success.
========== 2016.03.25 15:50:50 =====================
Result: Abort.
Packet: P3X_FW_V01.08.0080.bin
Upgrading ...
Upgrading ...
========== 2014.01.01 00:00:11 remo-con disconnect======
Upgrading ...
========== 2014.01.01 00:04:44 remo-con disconnect======
Upgrading ...
Upgrading ...
Upgrading ...
Result: Failed.
Result: Failed.
========== 2016.04.20 01:17:53 =====================
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
2016-4-20
heftrob
I too have the same RC signal lost. Tried most of what is in this thread. No luck. DJI????
2016-4-20
Pmarten8
Watch this it may help you it helped me to fix mine
2016-4-20
imagesbyjas
Flight distance : 286198 ft
Someone posted this on YouTube...
2016-4-20
DJI-Paladin
mrokay Posted at 2016-4-21 01:41
Upgrading ...
Oh i see. It would be better if you could upload the log file which is under the hidden folder MISC.
2016-4-21
