Ipad mini 2-16gb or mini 3-64gb or mini 4-16gb all wifi/3g ??
1093 7 2016-4-22
Mallettron
Flight distance : 82641 ft
Any ideas on which one would be the best?
Wifi and 3g because I need the GPS available (dont know why its not standard, all android devices have one fitted)
Videos and photos would stay with the camera so I dont need much storage
What about the processers, any problems with add on software (Airnest, Litchi or Autopilot)
Which is the best for visibility, do I need to get a sun hood
UK so lots of options from refurbished to new ones
Any suggestions appriciated
Thank you
2016-4-22
betoleal
Flight distance : 550472 ft
I would go with mini 3 64gb.
Yes, you need a sun hood to see it better.
2016-4-22
Sunny1975lucky
Flight distance : 38041 ft
The iPad mini 2 & 3 are basically the same, only difference is the 3 has fingerprint recognition.   The iPad mini 4 is faster and the screen is better as it's less reflective and easier to see outdoors.  I used my mini 2 to start with which worked fine but was hard to see outdoors so decided to get the mini 4 and noticed a difference straight away.
2016-4-22
DJI-Paladin
Flight distance : 2408 ft
Sunny1975lucky Posted at 2016-4-22 23:20
The iPad mini 2 & 3 are basically the same, only difference is the 3 has fingerprint recognition.    ...
Yes.Because of the A8 chip, mini 4's performance is higher than mini2 and 3.
2016-4-22
Mallettron
Maybe  a mini 2, cheaper to start with, I dont need all the bells and whistles as it will only get used with the P4, I'm an Android man normally but some of the apps are only IOS
2016-4-23
Nicola90s
Flight distance : 3060869 ft
I've a mini 2 only wi-fi 16GB and it work good. I use this iPad almost only for pilot the Phantom, I think that if you want some iOS device that is cheeper, a mini 2 is good enough.
2016-4-23
Mallettron
Been offered a mini 4 64gb, no 3g for 250gbp, 6 months old. I could get a seperate gps later
2016-4-25
Mallettron
I ended up with the mini 2 16gb wifi/3G from eBay, turned out to be 32gb and unlocked so was a bargain for 170gbp
2016-4-28
