Lightbridge Assistant Software
2445 7 2016-4-22
jpe2459
Will Lightbridge Assistant Software work properly with Windows 10?
Thanks
2016-4-22
DJI-Ken
Flight distance : 1515312 ft
Yes it should, if not you can try running in compatibility mode.
2016-4-22
gmarc007
I cannot get my LB assistant  software to recognize Lb using any of the methods mentioned..  tried 2 diff computers. need help asap as my Lightbridge needs stick calibration
2016-6-13
Tahoe_Ed
Flight distance : 2605 ft
Please try Assistant 2.  It recognizes many of our systems.
2016-6-13
jan
Flight distance : 3514751 ft
Denmark
Is there plans for Assistant 2 for MAC?
2016-6-13
gmarc007
Ed - Nothing!   My mid point are all of a sudden way out of wack and need to get into the assistant to hopefully calibrate and fix it.
2016-6-14
matthiggins87
I could never get LB Assistant working on Win 10 but it worked for me on Windows 7 or Xp. Make sure you also download and install the DJI WIN driver installer too
2016-7-5
emanuelevacca
same problem here. any workaround for windows 10?
2016-8-9
