nico
Hello,
I have the Lighbridge 2 with the A2 on an s900.
I'm trying to configure it.
There is a few things I can't seem to be able to do:
1) I can't get the a2 to go in failsafe mode when turning the tx off, the flight mode switch works, but when turning tx off, the flight mode stays in it's original position. I don't see any failsafe settings on the tx itself. Anyone with the same problem?
2) Since the cruise control and IOC need 3 ways switches, how do you make it work with the lightbridge 2, there is only one 3 way switch for the flight mode. Dji says LB2 is compatible with the A2, so surely we should be able to use the functions of the A2. How did you guys do it?
Thanks lots
Nico
