whyley27
i would take the top off and have a visual inspection of any soldered joints and any plug sockets on the board. looks like the battery is powering on but nothing is getting to the main board. have you shook the p2v a little to see if there is anything loose inside..
its just an idea, but anything with a battery sometimes its either a solder joint wire come loose or a plug come out of its socket
if it was a major crash, the main board may be split, thus having the PCB board connections broken. only way to know is to have a visual check inside, or use a multimeter with a buzzer on it , which checks for continuity within conections.
hope this helps
