imagesbyjas
Flight distance : 286198 ft
Pidi...
It really sounds like you've got multiple issues going besides just the fact that the app isn't working. A few things.. (and I'll admit, grabbing at straws here). First, on the app.. I understand what you mean by using the "Home" button for the reset, but I didn't do that. I let iTunes handle the entire process. In my case I didn't have many other apps on the iPad Mini 2, so I chose to just set the entire thing back to factory fresh - no restoring, no backups, etc, a complete wipe out. On that try, I did go to the App Store, downloaded and installed 2.8. Again though, I totally wiped out the iPad through iTunes.. I'm on 9.3.1
I followed this set of instructions except I didn't make a back up..
https://support.apple.com/en-us/HT201252
For the firmware, there is a hidden file (besides the .txt file) that is written to the Micro SD card which outlines the details of the hardware with respect to how the firmware is doing and provides a lot more detail. Search the forums for the instructions to get to that file, but it is basically just going to the properties and turning on the view for hidden files. Try the firmware update again (1.7 or 1.8) and copy the results of the hidden file and post them here.. It might help. There should be NO failures anywhere in that hidden file. If you're aircraft and RC are out of synch on firmware, it would make sense that the connection doesn't hold, so hoping that getting them at the same level will at least get them talking and linking correctly..
Hidden file instructions:
http://www.rcgroups.com/forums/showthread.php?t=2570015
