CE to FCC --> Is this possible
1594 12 2016-4-25
varunnahar
Flight distance : 42585 ft
Is it possible to change the settings to FCC from CE? I need to boost the range of my P3S and i dont want the after market accessories to do that.
2016-4-25
Larsaunitz
Flight distance : 384406 ft
Sweden
To my knowledge it isn't. FCC and CE is based on GPS, I think the whole Europe is in CE. Sweden is at least. I can get about 400-500 meters close to city and about 800-900 when I am in the outskirts.
2016-4-25
varunnahar
Tip: The post by the administrator or moderators shield
2016-4-25
pi-inthesky
Flight distance : 13058 ft
Larsaunitz Posted at 2016-4-25 18:41
To my knowledge it isn't. FCC and CE is based on GPS, I think the whole Europe is in CE. Sweden is a ...
Phantom 2 vision plus has the option to switch on the controller.Other models are as you described
2016-4-25
Scotflieger
Flight distance : 26875098 ft
You could always buy the P3A or P3P which are marketed for hobbyists and professional with the greater range. The P3S is for beginners and has a shorter range and performance to match. It is best to read the specs before parting with the money.
2016-4-25
Mariuss
Flight distance : 2480515 ft
Norway
anything new here? read a thread where they changed some code in linux, some worked others bricked the controller...
2016-7-11
DJI-Ken
Flight distance : 1515312 ft
No you cannot change the FCC/CE settings.
The Advanced uses Lightbridge and would give you way for range than the Standard.
2016-7-11
Mariuss
Norway
DJI-Ken Posted at 2016-7-11 20:12
The Advanced uses Lightbridge and would give you way for r ...
thats true, but then again i still wonder, if the advanced/pro has 3,5km while CE compliant why is the standard limited to 500 when its original range is 1km (1,2km for the 4k)?!
You cant hence the regulations, when the same class drone has many times the range?
2016-7-11
DJI-Ken
Mariuss Posted at 2016-7-12 02:52
thats true, but then again i still wonder, if the advanced/pro has 3,5km while CE compliant why is ...
It's based on regulations, the Standard and 3 4k are normal WiFi and that's what they are regulated to. The other aircraft use Lightbridge technology so it's not limited like those two.
2016-7-11
Mariuss
Norway
DJI-Ken Posted at 2016-7-11 21:22
It's based on regulations, the Standard and 3 4k are normal WiFi and that's what they are regulate ...
thanks Ken!
2016-7-11
DJI-Ken
No problem at all.
2016-7-11
papatita
Flight distance : 3282805 ft
Indonesia
Test CE to FCC:
2016-8-1
Baldo81
Flight distance : 2947493 ft
Portugal
I've read about a trick where you've to reset the ipad, etc... and the Phantom sets to FCC... I don't know the details but someoune was talking about this in a group on FB
2016-8-2
