Phantom 3 Standard - Memory Cards?
27948 15 2016-4-25
jp
Hello again Folks,
Just wondering if DJI or someone on here can advise in regads to buying a bigger memory card for my P3 Standard?
I currently have an 8GB SanDisk Ultra Mirco SD (Class 10), but can the Phantom take a bigger memory card say? 32GB? If so what Class is required for this?
Thanks
2016-4-25
phantom-four.co
Croatia
The Phantom 3 Standard  supports Micro SD cards with a capacity of up to 64 GB. Recommended is a Class 10 Micro SD card with a write speed of at least 40MB/s
SanDisk Extreme PRO 64GB UHS-I/U3 Micro SDXC is my favourite but others will do as long as you keep the minimum write speed in mind. Higher is better. With possible future upgrades in mind I would look at 60MB/s minimum.
2016-4-25
DJI-Paladin
Flight distance : 2408 ft
Hello jp, here are 3 recommended cards :
1)        Lexar 633X Class10 16GB MicroSDHC UHS-I
2)        Panasonic 16GB MicroSDHC UHS-3
3)        Sandisk Extreme 16GB MicroSDHC UHS-3
2016-4-25
jp
Thanks for the replies!
2016-4-26
Fernando2
Flight distance : 209491 ft
phantom-four.co Posted at 2016-4-25 04:17
I ordered the SanDisk Extreme PRO microSDXC UHS-I 64 gig card on the advice of someone here. I just received it and noticed it is not a class 10 card but has a 3 on the corner. Will this still work with my Phantom 3 Standard?
2017-5-12
Ryan Munsell
Will the sandisk extreme pro work
2018-10-12
Nebuchadnezzar
Flight distance : 3462946 ft
Ryan Munsell Posted at 2018-10-12 01:51
yes if it is Class 10
2018-10-12
solentlife
Flight distance : 1087530 ft
Latvia
My recc'd card as its not easy to get the Sandisk where I live and I don't like waiting postman :
Samsung EVO Plus 64Gb - (recc'd by my pal who's biz is IT .. it has a high write speed even though its read speed is lower than the Sandisk others recc'd).
Which by the way also says "3" on it but having used it for 4K in my P3P - I know works fine. I do actually knock back though to 1080 to get the high frame rate to avoid those jittery bits when yawing ...
Nigel
2018-10-12
Ryan Munsell
Totally ment to put the extreme plus
2018-10-12
Ryan Munsell
Well i am confused because i bought i dny class 10 card and it keeps telling me card error so not sure if it is card or not.
2018-10-12
solentlife
Latvia
If you get Card error on the AC and cannot format it there .... then try this :
On a windows PC - (I don't use Mac - so no idea there ...) - place card in reader and then into PC .... I recc'd do a FULL format to FAT32, not the quick format  .... which is what the AC would do if it could.
Do not format to any other ...... you can use EXFAT ... but there's no real reason to even with large capacity cards.
Once formatted ...  place back in AC and see what happens.
Nigel
2018-10-12
Geebax
Ryan Munsell Posted at 2018-10-12 05:00
It is most likely the fault of the card. If you want to be sure, then buy the Sandisk Extreme Pro, they work every time. Don't buy the Plus version, too slow.
2018-10-12
Ryan Munsell
After buyong the extreme plus and put in the ac thay card worked fine. Thanks for the replys
2018-10-12
Leo222
wanna delete it
2020-7-15
Leo222
damm it doesn't works
2020-7-15
Lenny13
Wanna ask. Looking for sd card Is there a difference in speed class? I mean UHS-I and UHS-III?
2020-7-15
