droneflyers.com
Flight distance : 60709 ft
You won't be able to use the gimbal with most all of them.
My suggestions are the following.....
At the low end, a Canon S100 or similar (s95, s110). They shoot raw and have a bigger sensor than most point and shoots. If you dig around and are patient, Canon will often have them on special as refurb with full warranty....
http://shop.usa.canon.com/shop/e ... 0-black-refurbished
Sometimes they are as low as $129, etc......
You have to install CHDK software (open source) which allows it to do interval shooting. You will not have FPV without some work!
At the higher end, the Ricoh GR - $600 for a very large sensor camera with top notch lens.
Both are about 200 grams - easy to lift when the gimbal is removed.
