CaptRuss
"... my friend is the designated drone operator for a leading edge engineering company here in Hawai'i and he is not certified as a commercial operator (Section 333 exemption)..."
Firstly, thank you for an interesting, civil and spirited discussion!
With regard to your point quoted above, the person with their hands on the sticks need not be the entity in possession of the Section 333 exemption for their aircraft. I have never argued otherwise. They merely need to possess a pilot certificate of some sort ("Sport Pilot" will suffice) themselves. However. the entity *utilizing the services* of the certificated pilot for commercial purposes (if it is not the pilot himself, and if it is not the pilot acting on his/her own behalf), though, indeed needs to be in possession of the exemption. That has *always* been my point. I have never argued otherwise; you need to read my points a bit more carefully & deliberately. My guess is that Matt, acting as the entire orchestra here, possesses neither the necessary exemption nor pilot certificate, although I may be wrong. If so, I apologize. However, my points, which you continue to miss, have consistently and simply been the following... and they have never other:
a) If Matt partakes in this commercial enterprise (see below), and he is the fellow with his fingers on the sticks, then he must be a certificated pilot,
b) If Matt partakes in this commercial enterprise, the UAS which he utilizes must bear a commercial registration number affixed thereto, not simply his personal registration number. If he has the latter, then that means that two FAA registration numbers would have to be affixed to his aircraft if he also utilizes it for hobby & recreational purposes,
c) If Matt partakes in this commercial enterprise, then either he, his company (perhaps an LLC like your own) or the PTO securing his services must possess the Section 333 exemption.
_____________________________________
"... As a non-commercial operator, can I fly a drone and record video for my company (an LLC) as long as I do not use the video as part of a commercial transaction with any customer?..."
Rather than answer that myself (I, too, have an LLC, and all my ducks are in the process of lining up in a row ;) ), the following extract from the FAA's own Interpretation of the Special Rule for Model Aircraft directly addresses your question as well as those characteristics that define commercial operation:
[4910-13]
DEPARTMENT OF TRANSPORTATION
Federal Aviation Administration
14 CFR Part 91
[Docket No. FAA-2014-0396]
Interpretation of the Special Rule for Model Aircraft:
"Not Hobby or Recreation (i.e.: Commercial Operation):
... A person photographing a property **or event** and selling the photos to someone else.
... Determining whether crops need to be watered that are grown as part of commercial farming operation..."
As mentioned in my previous post, "selling" need *not* involve the acceptance of monetary compensation; a simple "Thank you" from that someone else would qualify as payment. It is the "someone *else*" that is the big deal.
*If* your friend's engineering company possesses the Section 333 exemption, your designated pilot friend employee may record video *for the company* as long as he is a certificated pilot; I never implied that he would not be able to, and I never stated nor implied that compensation therefor was mandatory. Because it is for a company and not for his own hobby & recreational use, the operation is commercial in nature and, as such, he must be a certificated pilot. Can your designated pilot friend do so if his engineering company does *not* possess the exemption? Absolutely, unequivocally no. Conversely, would *you*, as an uncertificated operator of a UAS, be able legally operate the aircraft while & if *representing your LLC* to record video *for the company*? Again, absolutely and unequivocally no, because you would be doing it for commercial purposes as cited above (similar to "Determining whether crops need to be watered..."). In that instance, even though your company possesses the necessary exemption, its UAS operator (you!) does not possess the necessary pilot certification. Can you fly the UAS around to record video for your own personal records? Sure, but you may not do so on behalf of the company or your LLC. If you are indicating that you, your friend, and your friend's engineering company have indeed all done otherwise, then you are all lucky indeed and are tempting Fate ;). You state that one of the principals in the engineering company for whom your friend operates the UAS is an attorney; however, I suspect that he is not an aviation attorney. The above quote, extracted directly from the FAA's own statement speaks to that field of expertise. There seem to be several folks in this story whom, attorneys or not, are acting on their own behalf in [aviation] fields which are not necessarily their specialty.
Again, my points remain, they are simple, and they are not refuted by any of your terrific points:
* The enterprise is deemed commercial in nature because it is not for "hobby or recreational" purposes (see FAA extracts, above),
* No one either in, representing, or acting on behalf of, the commercial enterprise in which Matt is considering participating possesses the necessary FAA Section 333 exemption for the aircraft,
* The UAS does not possess the necessary commercial registration,
* Matt, if he is the operator of the UAS for the commercial enterprise, does not possess the required pilot certification.
My points have cited specific *existing* references, case law, FAA stipulations and regulatory extracts to support my points. Your arguments, although eloquently and passionately presented, have not.
In the final analysis, as I am certain that we have both pretty much exhausted the reserves on this one lol, thanks for a great discussion!
Matt: Even though Cetaman has already unofficially [ ;) ] cleared you for takeoff for this venture, I strongly suggest that you ponder, not just Ceta's impassioned interpretations, but more importantly, the cited references and that you, perhaps, consult someone vastly more qualified than either of us to offer you more expert advice. In any event, I know that you will decide wisely! |
