STANDARD: doa new unit wont turn on
darrin
Flight distance : 1004731 ft
brand new trying to follow instructions and when I turn on copter I get four lights red button light blinks then turns off..
five time in a row explaining to support so posting here..is this common? or a DOA unit..
Or a missing instruction...no idea.
thanks for any info cheers Darrin
2016-4-28
XboneDrone
Make sure you have fully charged all batteries....Pack that goes into the aircraft and the RC transmitter. When the battery pack is charging correctly you should see 4 intermittent lights blinking until it shows a solid 4 green lights. It will then shutoff and trickle charge. The transmitter will show a red light until it is fully charged and then turn green. I would start there if you haven't already.
There are plenty of notes posted throughout this forum to help. Just click on the magnifying glass at the top and submit a subject. Hope this helps.
2016-4-28
darrin
Thanks!! double checking everything on your advice! the remote was still charging..had bars..
I have submitted a video to support and getting a RMA, I will test a bit more but seems DOA..
cheers
Darrin
2016-4-28
Geebax
darrin@proimage Posted at 2016-4-29 08:47
I have ...
Just so you know, the RC unit takes several hours to charge initially, the flight batteries should take about an hour.
2016-4-28
DJI-Paladin
Flight distance : 2408 ft
Hello Darrin, if you still meet this issue, feel free to post a short video of it here.
2016-4-28
