DJI Ultimate Flight - Google Elevation and Digital Terrain Model
2723 16 2016-4-30
kenargo
DJI Ultimate Flight (DJI Ultimate Flight - v3 - Android Apps on Google Play) has just released a number of features specifically designed for waypoint flight operations.  The first and more general purpose facility extends the capability to define waypoint altitudes as "above ground level" (AGL), the second and more specialized feature if the capability to use "digital terrain model" (DTM).
First; "AGL" - When selecting AGL for the waypoint altitudes you can freely select altitudes that represent the altitude above the ground (not above takeoff as traditional).  Once the mission is designed you have 2 options for flight, the 1st is to fly the mission as-is.  When beginning an AGL mission the app will contact Google Elevation Services (GE) and convert between AGL to above take-off (ATO), using the home point as the elevation reference.  The second option is to define the mission using AGL and then toggle the option to ATO.  The app will prompt to convert AGL to ATO (again using WP1 or home point) and the mission will be converted to altitudes above takeoff.  Because GE may not be 100% accurate an additional review screen has been included to validate the elevation profile of the mission.
Second: DTM - DTM files can be downloaded or generated by any number of higher-end mapping and survey applications.  DTM files tend to be significantly more accurate than GE depending on the service used to generate the DTM file.  Once loaded onto the Android the DTM file is uses instead of Google Elevation.  DTM files can also be loaded during mission creation, displaying a bounding box representing the elevation reports of the DTM file.  Future enhancements to DTM file support will include the capability to display flight altitude "above ground".
Both features should be very helpful, especially to those flying in areas where ground elevation may not be perfectly flat.
When combined with the custom waypoint types (e.g., Orbit) the ability to create orthogonal imagery becomes much simpler.  For example, UF can generate a near-perfect orbit waypoint mission (you set the center, the app calculates the orbit's points).  If the ground elevation changes between waypoints then using AGL altitude will adjust the flight altitude, maintaining a constant above ground altitude which should yield significantly more accurate orthogonal imagery and calculations.
More details can be found in the app's documentation: http://djiultimateflight.com/images/DJI Ultimate Flight V3.pdf
Enjoy and fell free to ask questions as needed.
2016-4-30
treeboyy
Flight distance : 604747 ft
I like it I'll be testing this version soon.  I'm  not clear what type of DTM's the software consumes. I'm using Agrisoft and export as DEM. I'm curious about  doing arthoimagery missions in  DJIUltimateflight. Is there an auto-grid setup to facilitate various photo overlap (70-80%) requirements for mapping a certain area? Thanks for this I'm really looking forward to this.
2016-4-30
Domenico Panace
Flight distance : 34751 ft
iOS version? Where is it?
2016-4-30
ardrijewellery
Flight distance : 9827923 ft
Well Apple sell there Drones so I imagine it will be on its way soon..
2016-4-30
kenargo
Sorry, no iOS version is planned at this time.  I'm a 1-person shop, no time to add an additional platform.
2016-5-1
mrbillgill1
Flight distance : 717100 ft
Nice job on the manual
2016-5-1
Michael M
Flight distance : 1984898 ft
Wow 1k downloads at 26$ a pop. You must be loaded!
2016-5-1
Michael M
I would add a more appealing icon if I were you
2016-5-1
Domenico Panace
kenargo Posted at 2016-5-1 18:31
Sorry, no iOS version is planned at this time.  I'm a 1-person shop, no time to add an additional  ...
So you lose a lot of potential buyers. iPhone is THE PLATFORM!
2016-5-2
R&L Aerial
Flight distance : 298100 ft
Domenico Panace Posted at 2016-5-2 05:44
I think many pilots have both iOS and android version tablets, iOS tablets are usually in the 500 dollar range and good android tablets can go for as little as 200 dollars. I think more people will have android because of the lower price.
2016-5-2
kenargo
treeboyy Posted at 2016-4-30 13:17
I like it I'll be testing this version soon.  I'm  not clear what type of DTM's the software consume ...
Agrisoft can generate the DTM files; use the ASC format and copy the DTM to the tablet; there are instructions in the documentation.
Once the DTM is on the tablet you can load them (and the app will show the grid covered by the DTM) so you can verify the flight you plan is within boundaries.  Flying any mission the app will search existing DTMs and convert altitudes from AGL to above takeoff.
2016-6-8
kenargo
Sorry, no plans for iOS at this time.
2016-6-8
kenargo
Michael M Posted at 2016-5-1 14:14
Given the hours to develop and maintain the app, at $20 I doubt I'm even making minimum wage.
2016-6-8
kenargo
Michael M Posted at 2016-5-1 14:15
I'm not much of a graphical artist; the current icon was done by an icon creator.  If this is something you would like to help let me know and we can work something out.
2016-6-8
Michael M
kenargo Posted at 2016-6-8 17:32
I'm not much of a graphical artist; the current icon was done by an icon creator.  If this is some ...
Ive wirked in apps befote abd naking the icon is the hardest part. Even harder than all those stupid compilation errors. Ill see what i can do and pm you POSSIBLY IF i can produce something that doesnt look horrible.
2016-6-9
stephen_carney
Flight distance : 70873 ft
It looks good, bit windy here to try it out, but I can wait.
Looking forward to trying it out.
Cheers
Stephen (Bundaberg, Australia)
2016-6-9
kenargo
In beta, to be release later this week:
* Multi-select and edit waypoints
* Add support for older Android (down to 4.1 from 4.2)
* Long exposure panorama support
* Additional tweaks
2016-6-13
