Major update to DJI Ultimate Flight
kenargo
I've just completed a major update to DJI Ultimate Flight
App highlights over last version:
* Now supports Phantom 3 (Advanced, Professional, Standard and 4K), Inspire 1 (all models) and Phantom 4
* Phantom 4 support includes reporting of avoidance system status
* Orbit waypoint mode now included, no longer in-app purchase
* All new camera settings, all camera settings available through the SDK can be set (limited support for the X5/X5R and thermal image cameras)
* Exposure, both automatic and manual now available
* Touch-screen exposure setting (similar to DJI GO)
* Histogram with movable window
* Location report window can be moved
* Onscreen camera setting display and AE lock/unlock
* All new icons, looks more similar to the GO app for easy knowledge transfer
* New FPV screen with assisted takeoff and landing, also added buttons to set home point
* New camera widget, similar to GO app
* Touch HD image to setup HD communications link
* Touch battery image to configure battery warning levels and view battery cell and status reports
* Touch upper right image (pancake) to configure firmware distance limits, return to home and wall proximity setting
* All updated documentation (see: http://www.djiultimateflight.com/v3_documentation.php)
2016-4-30
FAS1
Sold!.....
2016-4-30
Domenico Panace
Flight distance : 34751 ft
Sorry Kenargo, I use only iPhone! No iOS? No your app;)
2016-4-30
Boblanglois52
Flight distance : 129567 ft
Copied from PhantomPilots.com
Is there a list of tested devices? I am using a Samsung Galaxy Grand Prime smart phone. It is not on DJI's list of approved. Everything works fine for the Go App except for Google Maps. That is hit or miss. Not sure if it's my phone, or the app. Not much of a problem so far as I have a P3Std. and try to maintain visual. Also, what are the in-app purchases?
2016-5-1
richmars
Flight distance : 209537 ft
Can't comment on the app (I'm sure I will soon) but it's great to see the documentation is ready. If you've spent the same effect on the app as you have on the manual it'll be impressive.
2016-5-1
kenargo
Boblanglois52 Posted at 2016-5-1 03:35
Is there a list of tested devices? I am using a Samsung Galaxy Grand  ...
There is a Google Support group which maybe the best place to ask about devices but I give a 7-day refund policy so you have plenty of time to test your device with the app.
2016-5-1
kenargo
Oops, missed part 2: there is a single in-app purchase which apps support for KMZ files.  KMZ files are special map overlay files, mainly used by environmental study and surveyors and allows you to load a map from a file (rather than Google Map).  All other functionality is part of the app.
2016-5-1
