Geebax
Actually, not even 2K as you call it. The stream sent to the RC unit and saved on your device is only 720p. It is only intended for you to be able to see what you are shooting. The real file is saved on the SD card in the aircraft, and to access that, you either remove the card from the aircraft, put it in an adapter and plug it into your compurer, or connect to the aircraft using a USB cable plugged into the gimbal assembly and download it.
