crash1sttime
Flight distance : 1047503 ft
Jello ?? what jello ?
That is absolute steady as a rock, not bad for a cheap gimbal eh, the true test is getting out in a large field and really giving it the full beans (speed) with lots of twist and turns.
As for the leg extensions, I didn't bother in the end, I keep the camera level on take off and tilt it once im in the air and then make sure its level before I land, if I want to take off and have the camera down to start with I just use a couple of small boxes to support the quad.
Its a pity the ear of the quad has to be trimmed though in order for it to work properly, however its no big loss as after seeing the difference in video stability I will never be going back to the fixed gimbal.
Im more than happy with mine, im going on holiday in September to Portugal and this was the reason I bought the gimbal, I didn't want the kind of video that looks like someone stuck an Iphone to a quad with sticky tape, which was what you got with the fixed gimbal.
I look back at some of my early videos and wonder why on earth I ever thought I was happy with the video quality.
There is one thing to be watching for and that is that the camera is levelled correctly before taking off, I have built a small frame that I slide under the camera and then press the button to run the calibration,
You do know about the small button on the gimbal board I take it, if not then run the SimpleBGC software that I pointed out in the video, the 5th tab is menu button make sure one click is set to "calibrate", then with the quad powered on press the button (I use a lolly stick) and the camera will go limp, hold it steady, it takes about 4 seconds, the camera will judder in your hand when it has finished calibrating.
Ive flown a lot and forgot to calibrate and ended up with a skyline that wasn't level,
You can set the software to skip calibration at startup, make sure this is ticked, you don't need to always calibrate, but just check it looks level, if not do the above.
Get yourself a YT channel and let me know the link, I look forward to more videos |
