Anything I need to know before flying over water?
749 9 2016-5-5
UFOJoe
Any guidance? I'm getting adventureous and want to fly my P3A over water. I have read that I should turn off the Vision Positioning and I have also read that I don't need to do anything special...except maybe have my mermaid close by and rested.
2016-5-5
ARM-001
Flight distance : 666893 ft
I would advise to start with a fully charged battery and wait until the battery has warmed to more than 25 degrees before flying over water. When you're over water, keep a close eye on your battery voltage. If it drops too low, bring it back in. Personally I also have a minimum battery charge of 40%, after which I'll bring it back over land.
Oh, and watch out for birds, they're not your friend!
Happy and safe flying.
2016-5-5
sevadu
Set your homepoint on a reasonable distance from the water, so the P3A won't accidentally land in water when RTH is used.
Golden rule (in my opinion): keep checking your battery all the time and don't push it. Bring the P3A back well in time. As always, first check the wind direction. In offshore wind, take into consideration that you will need more battery power to fight the wind when you bring the Phantom back.
Here are some useful links:
http://forum.dji.com/thread-36171-1-1.html
http://forum.dji.com/thread-47933-1-1.html
2016-5-5
skh1946
Flight distance : 126339 ft
I'm getting a little braver over water, this one was about 200' out over water. But heed the warnings above, I brought it back early
https://stebon.smugmug.com/Drone-Videos/i-p4xpZnx
2016-5-5
MrPinaColada
Flight distance : 790082 ft
Just think that there is really no difference between water or dirt. if it crashes from 300 feet it's basically going to be unrecoverable, whether it lands in water or dirt.
2016-5-5
G_MEZ_G
MrPinaColada Posted at 2016-5-6 11:17
Just think that there is really no difference between water or dirt. if it crashes from 300 feet it' ...
You're totally right!
2016-5-5
dobmatt
Flight distance : 1700092 ft
It's a different scenario when - say - lo batt or signal loss forces your bird to perform emergency landing. Note that you can tell her what to do when such things happen ...
2016-5-6
JtrJr-UAV Pilot
Flight distance : 4341 ft
UFO,
DON'T GO IN THE WATER!
Jerry
2016-5-6
JtrJr-UAV Pilot
JtrJr-UAV Pilot Posted at 2016-5-6 16:29
UFO,
Lakes too...(turn off the VPS)
Jerry
2016-5-6
TJ10
MrPinaColada Posted at 2016-5-5 23:17
Not if you have DJI Care, it'll be covered on the ground no matter where it falls from, unless it lands in water. DJI care doesn't cover water damage
2016-5-6
