DJI-Jamie
Flight distance : 112405 ft
Try this RC combination to attempt a reset:
- Turn on the controller, and leave the aircraft off.
- Press and hold C1, C2, and Shutter on the controller, which will generate a quick audio queue, then turn the controller off while still holding the buttons.
- When you turn the RC back on, you should be able to see the current RC information in the About section of the Camera View, update the RC firmware (if still not current), and be able to hold the Academy button to attempt a downgrade if necessary.
Please note that it could potentially reset the connection between your aircraft and RC, so you may need to link the two together again after performing this combination.
The main goal is to be able to see what firmware you're actually on, so that way you know what to upgrade/downgrade to. |
